[quote="Zippo"]From the context menu - > Properties entry of the junction,
is there any info as to what Junction Type it is ?
On my Vista machine, I've found that the Junction Type in question is a Mounted Volume.
These junctions were created under the Control Panel Disk Management GUI.[/quote]
Yes, same here. Mounted Volume created using the Control Panel Disk Management GUI.
I've found the same problem on version 9.1.0.5. If I go to Computer Management and mount a drive as a folder, then create a text file in that folder and delete it, Opus won't refresh automatically. If I install Opus 9.1.0.2, it works. Tried same thing on XP and Vista, same results.
All seems well here.
I've such a wormholed and nested mess of test junctions here,
both Mounted Volume and File Folder,
that I'm frequently becoming disoriented.
If only my computer had an internal Brunton Compass,
or DOpus had an integrated Star Map.
In any case, file copy, move, and delete operations are auto-refreshing within all my test junctions .
Thanks very much Jon !
Maybe I can delete all those test junctions now.
Using Vista32 here.
