Hi
The default Archive (Ctrl-4)
action is to call ADDTOARCHIVE
which has different semantics to the ARCHIVE
command wrt the keepfolders
option.
The ADDTOARCHIVE
command has the same behaviour as ARCHIVE=keepfolders
, but what I need is the opposite.
Is it possible to get the dialog from ADDTOARCHIVE
, with the behaviour of ARCHIVE
when a single folder is selected?
As an aside, the ADDTOARCHIVE
command (and probably most variants of COPY
) accepts the TO=
option to set the destination path, but does not seem to accept {destpath}
style codes. Is this correct? I'm currently working around this with a script, but it seems unnecessary.
Many Thanks
