Sorry, i have no idea how to install the script into the rename section. What is an orp file?
Thanks, i'm also investigating. I actually did not use that rename panel for many years, only my customized MP3 renaming tool bar, so i forgot a lot of stuff. Now i have found how to import the orp intoo the extended rename section. I will make a test run on some copies of my photo folders.
I think it would work with the Created timestamp. AFAIK that won't normally be changed. (Using the Modified timestamp instead would be a bad idea though, on folders.)
Yes, folders seem to be a special case. I will run the test now, let's see.
Hmm, nothing happened. I was expecting the created dates to change. Edit, no wonder, i still could't install the js.
Yes. And actually... you should do it. You kinda deserve it.
I have copied the js script into the field, but it won't let me safe it. Either i abandon it, or i can't click "ok". Sorry for not understanding all this stuff. Thanks for trying to help me.
Ok, don't bother. I give up. And that's it for me in this forum so far.
Saving rename presets is done via the buttons above the presets list, at the top left of the dialog.
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Rename_Presets.htm
