Keyboard command help
what's the command for
"display this folder in the other file display"?
I want to create a keyboard shortcut for it.
thanks
Go CURRENT OPENINDEST
if you meant the current folder.
Go {f} OPENINDEST
if you meant the selected folder. (Also works on files.)
