Keyboard monitoring also if not focused
Hi all,
I found a strange behaviour about keyboard monitoring. I set the enter key to execute the script
go fromsel
select first
to auto select the first item after entering a folder with enter key pressing. It works well in DOP BUT, suppose that I want to delete a selected folder, so I press DEL key and the windows message asking me if I want to delete appears. Now the windows message has the focus and I press enter key to confirm. The result is that I enter the folder and the confirmation message is still open.
One more: I must terminate DOP to be able to use enter key writing this note. If I don't terminate DOP pressing enter key does nothing.
I think that keyboard monitoring is a little bit pervasive :slight_smile:
(Window XP SP2, Opera)
Thanks in advance for a reply, Umberto
Ok ok, I got it.
I missed the "System wide hotkey" checkbox.
Sorry.
