These small buttons quickly enable or disable your desired lan-adapter using Windows built-in netsh command (e.g. if you don't want an application connect to internet):
Within code replace NAME_OF_LAN_ADAPTER to yours.
Enable:
@runmode hide
netsh interface set interface NAME_OF_LAN_ADAPTER enabled
Disable:
@runmode hide
netsh interface set interface NAME_OF_LAN_ADAPTER disabled
Nice. Don't forget to add the @admin modifier, or it won't work.
For convenience, here's the code to paste onto the toolbar. Modify as needed.
<?xml version="1.0"?>
<button backcol="none" display="icon" separate="yes" textcol="none" type="three_button">
<label>Toggle LAN Connection</label>
<icon1>#ftpconnect</icon1>
<label>Enable LAN</label>
<icon1>#mapnetworkdrive</icon1>
<function type="normal">
<instruction>@admin</instruction>
<instruction>@runmode:hide</instruction>
<instruction>netsh interface set interface LAN enabled</instruction>
</function>
</button>
<label>Disable LAN</label>
<icon1>#disconnectnetworkdrive</icon1>
<instruction>netsh interface set interface LAN disabled</instruction>
</function>
</button>
</button>
Yes, but only necessary when you aren't admin.
You can also add another adapter in the commandline (e.g. when you have ethernet and wifi).
