Starting a lasso selection at 'config' (2nd line in screenshot).
...but final selection does not include that item.
Lasso settings:
Using Details mode in v13.7.1.
Lasso settings:
Seems to be a a side-effect of using Ctrl for that option. We can probably improve that, but you can avoid the issue by changing it to use Shift or Alt instead.
Fixed in the next beta.
Verified OK, thanks!
