Birba
April 13, 2025, 8:53am
1
I have internal zip file support enabled but I would like to change the left double-click command. Unfortunately, once changed, if I exit Dopus completely and restart it, the default "Go" command always returns.
But is this behavior correct?
lxp
April 13, 2025, 9:51am
2
Yes, if you want to change the event, you need to turn off Preferences / Zip & Other Archives / Zip Files / Enable internal Opus Zip support .
Birba
June 8, 2025, 11:51am
4
On startup, Opus no longer "repairs" the .Zip file type events (Opus-specific events for double-click, double-click + shift, etc.).
The default events now only come from the Archives file type group, without the .Zip type adding further overrides.
As well as simplifying things, this means you're now free to modify what happens when double-clicking Zip files inside Opus (e.g. if you always want Zips to open in a new tab, you can do that now).
Beta 13.16.1
That's exactly what I was looking for. Now I can customize the command
Thanks
