When MS paint is removed from Windows optional features, DOPUS still has context menu entry for it on images. Doesn't appear in explorer context menu.
The entry must still be in the registry. If you search for that string using regedit you should find it.
Ok it's solved, had to remove
Computer\HKEY_CLASSES_ROOT\SystemFileAssociations\.jpg\Shell\3D Edit
