Lister Filter Auto Select Content
I have started using the filter using the * key in lister display frequently now to search for files having specific phrases in it.
However, I find that when I change focus to go to another window e.g. Web Browser and come back to the Directory Opus Lister and click in the search box next to the filter, I have to manually erase all the characters entered or manually select the existing contents to write new phrase there.
Is there any way through Settings so that when I click in the search box next to the filter, it auto selects the existing phrase entirely so that when I start typing it erases the previous contents automatically. It will save extra work every time I click in the Search box.
If not, some other way to achieve the same in a given Lister to search for files will be also useful.
I am not particularly fond of FAYT in the situation I want to use as it shows all files and even with : it selects the files and does not restrict the display for showing only files having the search phrase in name which means I need to scroll through or tab through to find all files.
We might change this in the future but there isn't an option that will change it now. You'd have to double-click the string after clicking it the first time, or push Ctrl-A after clicking it once, or activate the main lister (instead of the filter control) when coming from the other program and then push * again (which will highlight the whole string).
This is what I am doing currently and each of the other methods described also involves extra clicking or typing which I wanted to know if it can be avoided.
Looking forward to early implementation of the auto select feature for existing phrase.
I don't understand this comment. If I enter * followed by abc, I see only the files whose names contain abc .
* opens the Filter and will restrict files shown.
FAYT opens as soon as you start typing highlighting the files in entire set.
