I have read the FAQ and have been playing around with this for a while now, but I cannot seem to get it to work the way I want it to work.
I use the tabbar on top to switch between one mode and another. For instance I have one called Laptop which auto loads the directories i want when i first load it and in the format I want. I use another one called "images" and it switches from dual mode to single mode in thumbs view.
However, when I switch from one to the other, the width of the folder tree window changes. I want the folder tree to remain a certain size. I created the layout under the "laptop" tab to the width i want and then saved it. If i close and restart the lister it remembers it. If I click on "laptop" the width changes to something wider, and if i click on "images" it goes even wider, only allowing 3 thumbs across instead of 4 that I want. If I close the lister and restart it, it is back to the way I had saved it.
What can I do to either have 2 different widths for the folder tree section or make it narrower and keep it at that width no matter what tab i use on top?
I guess the same goes if I want to have my display in dual mode, but have them 2 different widths instead of splitting it evenly.
Hope i was able to make that clear, if not I will be happy to try to explain it better.
