Sometimes when I call up my default lister, one or both panes will show blank. I have to navigate to another folder and then back again to get the files and folders to show. Or, if I start clicking on files, they will start to show one at a time.
I am running on an HP laptop with a Radeon IGP XPM graphics card
XP Pro SP2
DOpus 8.2.1.0 U
If it matters, I have the same problem particularly when pulling up a tab group. I have to hit F5 Refresh in order for the folders/files to be displayed in the pane.
Yeah Leo - this is the same as that other issue were talking about not too long ago with large icons and thumbnails (BTW, I'm having trouble finding that topic when I do a search... have you been having problems like that lately)?
More info: I have 3 tabs in a particular group. They launch without a problem, but the first tab is blank. If I start to click on the other 2 tabs, their files will be displayed normally. If I click back on the 1st tab, it too shows it's files.
I bet if you drag another window over the top of Opus it'll also cause the files to appear. Sounds like a simple painting problem when listers open in List or Thumbnails mode.
I literally never use List mode so I won't ever have seen the problem there, but I do open a Thumbnails mode lister every so often, via a layout for all my music albums, and I've never seen the problem there. It may only happen with particular hardware/drivers or other settings (e.g. tabs) though, so maybe I'm just lucky.
It seems to just be a problem with the initial lister tab when you've set the layout view-mode to be something other than details. The way I'm reproducing it is by updating the 'default lister settings' based on my normal saved layout, and I'm getting the same problem with list, large or small icons, and thumbnails.
It's looked at by the GPSoft guys occasionaly... but you DO need to fill out a support request through their webpage. Feel free to refer to this topic as you explain the problem when you submit the report to them though... but do provide an explanation in the report you file with them.
What are you using to provide your visual theme? WindowBlinds?
Maybe try disabling whatever you use and just go back to standard XP Luna theme and see if it makes any difference.
There is no WindowBlinds. I am simply using a Windows theme with a modified uxtheme.dll. This is what I have been using for years with no problems in any other program.
I just tried going back to Luna Theme but that didn't solve the problem. I loaded DirOpus on my wifes desktop and I have the same problem there.
Yes, there are a lot of common programs. I'm not sure what you mean by third-party programs. But, nothing that would mess with screen display. I turned off Powerpro just to make sure but that made no difference. I have no other utilities that would interfere with a screen refresh.
You can see from this thread that it is not only me with this problem.
When I call up the lister I can get the screen to display if I click on the folder name in the lister. I guess that does a refresh. Very annoying.
Ya know Ed... Jon is just trying to help logically deduce what might be causing the problem. Third-party means 'things that do not come with windows' by default.
Anyhow, I also can produce the problem in 'list' view-mode as well. I basically positioned a lister loaded from my normal saved layout to the folder in the screenshot, clicked Settings->Set As Default Lister, and then launched the default lister layout by clicking on the Opus shortcut on my Quick Launch bar.
For the life of me I also can't think of anything particular that I'm running that could be causing the problem.
I have noticed however that if I delete the HKEY_CURRENT_USER\Software\GPSoftware\Directory Opus reg key, exit Dopus and restart it... I cannot reproduce this problem by repeating the steps above. If I import my 'normal' DPS file back again, I can reproduce it immediately by updating my default lister settings to either thumbnail or list view-modes and then launching a default lister...
That is exactly what I'm doing. I created a layout that shows "D:\My Music" in a single pane with List view. When I call up that layout from a shortcut, I get the problem.
I changed the view mode in that layout to details and it works perfectly. The problem only seems to be in List view.
I just created a layout in 'list' mode and saved it to the desktop. Launching it from either the desktop or quicklaunch toolbar results in the lister opening normally.
Seems to imply that it's something unique to your systems - perhaps we can start with both of you listing all the apps running at the time.
(Steje: Have you forgotten you're a beta tester? )
