Lister state after restart
Hi,
the following problem I've had since version 9
Multiple listers are open and maximized. Now if I completely quit Opus
or restart my computer, then the state (maximized) of all listers will be restored.
As one would expect. As long as they were not minimized.
If I minimize the listers , Opus are stopping and restarting, the listers while
further minimized, but after clicking on the task bar they are not maximized
shown but in its default size and position, although they were previously maximized.
I see a problem here where there is none or is there a simple explanation and solution?
Thanks for telling us about this.
A fix has been written and will be included in the next update.
[quote="leo"]Thanks for telling us about this.
A fix has been written and will be included in the next update.[/quote]
Thank you for the feedback.
To all who can not wait. In version 10.0.0.2 of the beta error was fixed. I've installed it with me and can confirm it.
http://blog.dopus.com/2011/05/directory-opus-version-10002-beta.html
The maximization problem has been fixed in the beta now. Unfortunately, the maximization in
Windows 7 is just one part of the problem. Windows 7 has side anchor points. Now, if a window
is anchored on the left side and is another window on the right side anchored, then this state
is not restored after a restart of Directory Opus 10.0.0.2 Beta.
Microsoft did not think to provide an API to allow programs to know when they are docked to the sides (or vertical-only maximized) so we can't do anything about that, sorry.
