ListView Control suggestions
A few requests/suggestions for configurable options for the listview control in script dialogs.
  • Background colour.
  • Text colour.
  • Individual item text colour.
  • Grouping - create and assign items to groups.
  • Font size.
  • Enable / Disable item in list.
  • Edit subitems inline.
Thanks for considering.
What do you mean by "enable / disable item" ? So that it wouldn't be selectable at all?
(If you use checkbox mode you can already disable the checkbox).
Yeh, in the list but unselectable. The thought behind it - in my Global Variables script I would like to have any vector or map variables listed - so I can see they are there but can't actually select them.
Thanks.
Most of these are in 12.20.8 (all except the font size and editing subitems, which is more complicated).
Nice one. Thanks.
