Is is possible that DO can consider implementing Live Mesh integration as at the moment to work with Live Mesh files and folders I have to drop back to using the Vista standard explorer?
This is primarily a user-to-user forum and while GPSoftware do read it there's no guarantee
that they'll see or respond to a particular post like there is if you contact them directly
