Load factory default settings
Hi,
Is there any way I can load back the factory default setting of OPUS 10? I cannot find it in the application.
To do a full config reset, uninstall Opus and then reinstall it.
But you can reset most things by doing this in Preferences:
And this to your toolbars (right-click on the empty part of one):
