Load Lister when Opus executes
This will execute Opus perfectly for me.
SubMain
AppBringUp "C:\Program Files\GPSoftware\Directory Opus\x86\dopus.exe"
EndSub
But as soon as I add "//cmd Prefs LAYOUT=opusOneNote" (OneNote being the Lister name). It will not run.
SubMain
AppBringUp "C:\Program Files\GPSoftware\Directory Opus\x86\dopus.exe //cmd Prefs LAYOUT=opusOneNote"
EndSub
Is there a special code that Opus wants regards to loading the Lister.
Bob
The command you need to bring up your named lister is dopusrt /acmd prefs layout=opusOneNote
I did not get it to work. But most likely I might not have the path correct. I will list below the paths. Also The lister name, now, is "Bob". Not that it matters much.
Sub Main
ShellExecute "C:\Program Files\GPSoftware\Directory Opus\dopusrt /acmd prefs layout=opusBob"
End Sub
Sub Main
AppBringUp "C:\Program Files\GPSoftware\Directory Opus\dopusrt /acmd prefs layout=opusBob"
End Sub
C:\Program Files\GPSoftware\Directory Opus\dopus.exe
C:\Users\ameri\AppData\Roaming\GPSoftware\Directory Opus\Layouts\Bob.oll
I'm using Windows 10 Pro 64bit.
directory Opus 12.26
Bob
It looks like you have the quotes in the wrong places, but it's hard to be sure as you're posting Dragon Naturally Speaking code, and that isn't something I've used.
