would like to have this feature:
double left-click on the blank area to locate at upper directory
and
press hotkey "ALT+UP" to locate at upper directory (supported by windows explorer)
and
Set Preferences / File Displays / Mouse / Double-click on file display background to run:
Go BACK UP
or similar.
Go to Settings > Customize Toolbars > Keys and you can set up any hotkeys you wish there. The command would be the same, and you would want to create a lister hotkey.
(Using the default Backspace hotkey seems easier than Alt+Up, though!)
Thanks for yuor help! (so quickly and clearly)
I've got what i want.
by the way, Backspace is not equal to Alt+Up on windows explorer.
Depends which version of Explorer, but yeah, it does something weird in newer versions of Explorer. (Something like: "Go Back if it's a Thursday before 7pm except the 2nd Thursday of each month, and Go Up otherwise." We have no desire to emulate that. :))
