Location of Viewer Pane
Hello All,
I am using DO12.26.
Is it possible now to move the viewer pane to the far left? (I'd like to keep it the same size while adding additional file displays to the right. Also, on a large monitor with 2 windows open, it is easier to see the viewer pane when its nearer the middle of the screen.)
If not, could that be incorporated in a future release?
Only options currently are on the right and on the bottom (or off entirely, or in a separate window).
