Locked Tabs always visible
Hey,
i use the locked tab feature to hold my linkfolders to my running projects.
It would be awesome if i can see my locked tabs all the time.
You mean even when a lot of other tabs are open and scroll the locked ones off the side?
Using toolbar buttons for the folders you always want quick access to may be a good way to solve that.
