I found that in DO, long file name display is a problem.
When a file name contains much information, with length over 100 (less than 255), it's whole display would be a problem.
For example:
(20200102-130843)Noodle#Delicious#Friend@John@Henry^John_and_I_learned_cooking_noodle,_his cousin_was_naughty_by_side.mp4
(20200102-130843)Noodle#Delicious#Friend@John@Henry^John and I learned cooking noodle, his cousin was naughty by side.mp4
The non-space file name above can't displayed in multiline with Thumbnail display mode unless I manually add spaces to it's proper place:
More over, the metadata pane don't have a multiline filename column. So it's not easy to see the whole file name.
The only way I can find to show the whole name, is to hover the mouse on the file, wait for some time, see the popup info:
But that method is slow, no efficiency. Plus, the popup info box is too wide, it'd be better if it can auto-warp when the filename is too long.
Is there a proper way of handling bunch of long filename files? (I use filename with sufficient information to manage my photos and videos, it really matters)
