Lookup Ham Radio Call Sign
So this is my first button/script post.
I needed something to do Ham Radio Call signs without having to go to a Web Browser. So I wrote a PowerShell Script and created a button for it. Sharing here in case there are any other HAMS out there.
Here is the Button Code.
<?xml version="1.0"?>
<button backcol="none" display="both" textcol="#00ffff">
    <label>Call Sign Lookup</label>
    <tip>Lookup a Ham Radio Call Sign</tip>
    <icon1>#newcommand</icon1>
    <function type="normal">
        <instruction>powershell.exe -noexit C:\Scripts\Callookinfo.ps1 {dlgstring|Enter Call Sign} {dlgchoose|Select Output Type|TEXT=text+JSON=json+XML=xml}</instruction>
    </function>
</button>
Here is the PowerShell script Callookinfo.ps1.
.SYNOPSIS
  Ham Radio Call Sign Lookup
.DESCRIPTION
  This will do a Call Sign Lookup from https://callook.info
.PARAMETER CallSign
           <Ham Radio Call Sign>
           OutputFormat
           <Format desired for output (json, xml, text)>
.INPUTS
CallSign
OutputFormat
.OUTPUTS
  Call Sign Information in format Requested.
  Output options: XML, JSON, TEXT
.NOTES
  Script Name: Callookinfo.ps1
  Version:        1.0
  Author:         Richard Knechtel
  Creation Date:  11/08/2017
  Purpose/Change: Initial script development
.EXAMPLE
powershell.exe C:\Scripts\Callookinfo.ps1 KD9HSO text
#---------------------------------------------------------[Script Parameters]------------------------------------------------------
param(
[Parameter(Mandatory=$true)]
[string]$CallSign,
[ValidateSet("json","xml","text")]
[string]$OutputFormat
#---------------------------------------------------------[Initialisations]--------------------------------------------------------
#Set Error Action to Silently Continue
$ErrorActionPreference = 'SilentlyContinue'
$global:ReturnCodeMsg = "Completed Successfully"
#----------------------------------------------------------[Declarations]----------------------------------------------------------
#Script Version
$sScriptVersion = "1.0"
#-----------------------------------------------------------[Execution]------------------------------------------------------------
try
  # Lookup Call Sign
  $Response=Invoke-WebRequest -Uri "https://callook.info/index.php?callsign=$CallSign&display=$OutputFormat"
  Write-Host $Response
catch
  # catch any errors and report them
  $ErrorMessage = $_.Exception.Message;
  $FailedItem = $_.Exception.ItemName;
  # Set return code/message
  $global:ReturnCodeMsg="There was an Error in Callookinfo.ps1."
finally
  # Do any Clean up here
# Some Value or Variable
return $ReturnCodeMsg
