Loosing Keep on top settting for custom toolbar
Since (probably) 13.7 update my custom toolbar looses the Keep on top setting. Is there a workaround for this?
Or does somebody know where i can find the setting in the configuration files?
It's not in the toolbars dop file.
If it's not already, turn this on:
Preferences / Toolbars / Options / Save state of floating toolbars automatically on exit
Or manually save the state, via the "hamburger menu" (three lines) at the top-right of the Customize dialog.
Ah, thanks. :+1: I somehow overlooked this setting. :sweat_smile: At least the setting gets remembered now.
But I still have the problem that maximized windows lay bellow the toolbar (so that the close button is bellow my right screen border toolbar). Is there also a setting to not overlay Windows?
If the toolbars are docked to the edge (not just floating near it), and not set to auto-hide, maximized windows should not overlap them.
Things can go wrong here if you’re using multiole monitors in different DPis, or change DPI after boot, due to Windows bugs.
Ah, man, unlocking and "redocking" solved the issue. Should have thought earlier about this.
I am getting old. :sweat_smile:
