Losing rename info in rename requester
Hi guys,
You know I'm in love with your revised rename tool - there's still a detail I would recommend to improve. I've lost entered filenames several times.
Here's what I've done, using Opus 12.0.11:
1.) Select several files
2.) Open the rename function in 'Standard wildcard rename'
3.) Disable all options and actions but 'ignore extension'
4.) Double click on the first filename in the 'New Name' column
5.) Make some changes, do NOT press return.
6.) Double click on the second filename in the 'New Name' column
7.) Make some changes and press return (Do not use the mouse to click the buttons!)
The rename requester closes immediately, executing the first rename, but ignores the second string that was entered. The're is no change on the last item and the entered rename info is just lost.
Hope it's not on my machine only again:)
I've lost renames several times because of this behaviour. I think it would be nice if the first return would just exit the edit control instead of closing everything. What do you guys think?
Thanks,
Kind regards.
For me, the first return (while the New Name column in the preview list still has input focus and is being edited) only stops editing the line. I have to push return a second time to close the dialog.
That seems like what you're suggesting already, but maybe there is a situation where it doesn't work like that? (It's also possible this was changed in our internal build and hasn't been released yet.)
Hi Leo,
thanks for your reply.
Bah, it seems it's my machine only again, lol. Have the same behaviour in 12.0.12. Pressing return immediatly closes the dialog, so I always miss the change on my last item.
Any idea what the reason could be?
Thanks.
