dsotm
June 13, 2008, 1:22pm
1
Yesterday my FTP stopped working in Dopus. 9.1.0.6
If I boot and use WS-FTP or Dreamweaver etc before I open Dopus I can connect fine. BUT if I open Dopus and try to connect, not only does it not connect to any site in Dopus but thereafter no other software will connect either until I reboot.
Any ideas?
Brian
Did Windows update itself for you too?
It did here. Haven't tried FTP, but stranger things have been known to happen after Microsoft weaves its monthly magic.
dsotm
June 13, 2008, 2:21pm
3
I am using XPSP2. Updates are set to auto so I am not sure if this is related - its driving me mad!
Brian
Leo
June 13, 2008, 2:28pm
4
Sounds like a firewall or port mapping issue to me.
Are you using a software firewall? If so check its logs.
Also check the Opus FTP log via Tools -> Output Window to see if there's any useful information in there.
dsotm
June 13, 2008, 3:32pm
5
I am using Windows firewall. Is there a place to check the logs?
In Dopus the FTP log gives the following:
Opening Connection ftp.bsbit.co.uk:21
Connection closed
Thats all
Brian
Leo
June 13, 2008, 3:40pm
6
Does basic command-line FTP work to the same site?
From a command prompt:
ftp.exe ftp.bsbit.co.uk
Have you tried setting the site bookmark in Opus to use PASV mode (or to not use it, if it's using it at the moment)?
