The Go command with the FOLDERCONTENT option produces potentially long lists, that even extend beyond the lister, if it's not in full screen mode, like so:
Very practical, but is there a way to stop the list from expanding above the button so it doesn't block the adjacent menu items? Would make the navigation a bit easier.
I don't think there is, other than moving it into a submenu or filtering it to reduce the number of items (e.g. you could split it into two using different filters for each).
If a menu won't fit below or above the button that opened it, it will open to the right or left of the button.
