Menu to display picture
I use the following to show a picture. The problem is that the picture comes ion a window, Windows Photo Viewer, not needed.
Bob
You've said what you don't want to happen but haven't told us what you want to happen instead.
Windows opens pictures with this program by default (if you don't have installed ACDSee or similar viewers). If you want to use DO's internal viewer in preferences set DO to show pictures.
You've said what you don't want to happen but haven't told us what you want to happen instead.<<
Sorry. I took note of the issue after the review and post. I did not see a way to edit the replay.
I'm looking for a solution that will show only what is in side the white area.
Bob
I did find a way to display very little over head. It's ancient, Slowview. Know I need to have it call the right picture. I no longer have the instustions for the viwer but most work by listing the picture after the exacute command:
None of the following worked - I tried both JPG & PNG
C:\Prg\Graphic\SlowView\slowview.exe
Function: C:\Prg\Graphic\SlowView\slowview.exe @OpusTopic.png
Start in:
Start in: C:\Prg\Graphic\SlowView[b]@OpusTopic.png[/b]
Start in: @OpusTopic.png
I entered the picture manual. I'm hoping to find a way to create a button that can display the picture needed for each example I use.
Bob
See the docs on the internal Show command.
