A middle-click menu, using jscript and a dialog, for the purposes of doing things like toggling toolbars and thumbnail labels etc. Written as a command that can be assigned to middle-click actions.
is it possible to have no titlebar.
is it possible to click outside the dialog to close it
is it possible to have the dialog appear under the mouse pointer
Having trouble with quotes in quotes when calling RunCommand().
Here is code (pretty short for what it is) the relevant bits are in vCommands[1 and 2], choice 1 is called but does not do anything choice 2 works as expected.
//Popup List for middle-click button
// Initialize script
function OnInit(initData)
// Provide basic information about the script by initializing the properties of the **ScriptInitData**object
// https://docs.dopus.com/doku.php?id=reference:scripting_reference:scripting_objects:scriptinitdata
initData.name = "Popup List"; // Script Add-Ins name
initData.version = "1.0";
initData.copyright = "(c) 2023";
initData.url = "https://resource.dopus.com/t/iconset-https://resource.dopus.com/t/how-to-use-buttons-and-scripts-from-this-forum/3546/3maker-v2/42158/2";
initData.desc = "Simple popup list called as a command, can be bound to mouse background events";
initData.group = "Commands";
// Create a new **ScriptCommand**object and initialize it to add the command to Opus
// https://docs.dopus.com/doku.php?id=reference:scripting_reference:scripting_objects:scriptcommand
var cmd = initData.AddCommand();
cmd.name = "popupList"; // command name
cmd.method = cmd.name;
cmd.desc = initData.desc;
cmd.label = initData.name; // customize dialog name
function popupList(clickData)
DOpus.Output("before dlg.Show() ");
var vChoices = DOpus.Create.Vector
"A Choice 1",
"B Choice 2"
var vCommands = DOpus.Create.Vector
"Toolbar 'Images' STATE=bottom TOGGLE LINE=0",
"Toolbar Images STATE=bottom TOGGLE LINE=0"
var dlg = clickData.func.Dlg;
dlg.choices = vChoices;
dlg.menu = 0;
dlg.Show();
if (dlg.result)
DOpus.Output("cmd called");
cmd.RunCommand(vCommands[dlg.result - 1]);
DOpus.Output("after dlg.Show() " + " --- " + vChoices[dlg.result - 1]);
DOpus.Output("Return code = " + dlg.result);
if (dlg.result) DOpus.Output("Command = " + vCommands[dlg.result - 1]);
