In v12-video all menus (kontext) have icons... in my config not (maybe because it's coming from earlier versions). If I add the icons manually, which file(s) do I need to copy to my other installations?
It can depend which menus you edit.
For the non-filetype menus, it will likely be some of the files under /dopusdata/Buttons/Menus
For the filetype menus, if you edit them as well, /dopusdata/filetypes
I would make a backup of your config folder before adding the icons, then add them, exit Opus, and compare the two folders (e.g. using a tool like WinDiff or Beyond Compare, so you can see the differences within the files as well). That will show you all the files that changed and you can get an idea of what changed inside them, and choose whether you want to copy it to another machine.
I'll have a look.
Is there a way to restore them to default (w/o setting DO completely to default, like toolbars)? I didn't add many own entries into default (except own filetypes), so it may be easier.
I don't think the icons are part of the defaults, but if you delete the individual menus or filetypes then Opus will usually recreate them. Back things up first.
I'll try, thanks!
