Modifier @disablenosel for both filetype and nothing selected
For a few days now, I'm trying to create a button which becomes disabled when:
  1. Nothing is selected.
  2. Files with the *.lnk extension are selected.
I've managed to partially make it work with @disablenosel:!type=*.lnk, so the button will be disabled if the *.lnk files are selected. The problem is that the button gets enabled when nothing is selected, and I want it to also be disabled when nothing is selected.
I've tried all kinds of combinations (including adding an extra @hidenosel as a hack, but it doesn't work in conjuction with @disablenosel -- is that by design?).
The krux of the problem is (as per docs) that the negation ! must be the first thing after the colon : (and it applies to the entire line), so something like @disablenosel:files,!type=*.lnk is not doable, neither is this syntax valid @disablenosel:!type=*.lnk,!files to flip the negation. Using multiple @disablenosel also doesn't work.
Try files,type=~(*.lnk)
Not sure if it'll cover all the cases, but I think something like that has worked for similar problems.
Thanks Leo, it works!
This syntax seems to enable more flexibility and presumably works everywhere throughout the Opus?
~ should work anywhere wildcards work, yeah.
Great! I hope the docs will be updated at some point :slight_smile:
~ has been in the docs for years. It's part of the wildcard syntax.
I primarily meant for the examples in the Command modifier reference, it didn't even occur to me to try the wildcard syntax for the @disablenosel because although the Standard wildcards are mentioned (and Pattern Matching Syntax is linked elsewhere for some other modifiers I wasn't interested in), the examples given for @disablenosel use their own syntax (! for negation) so I missed it.
They're two slightly different things.
  • You can invert the @disablenosel requirements with ! at the start.
    That includes things which are not wildcards. e.g. @disablenosel:!files means the button is only enabled when no files are selected:
    Nothing selected -> Enabled
    Folders (only) selected -> Enabled
    Files (only) selected -> Disabled
    Files & folders selected -> Disabled
    That's different to @disablenosel:dirs which is enabled if folders are selected:
    Nothing selected -> Disabled
    Files & folders selected -> Enabled
  • You can invert wildcards with ~.
    That's just part of the wildcard syntax. It wouldn't make sense to re-list all of the wildcard syntax everywhere wildcards come up in the manual.
In some cases you can do the same thing using either method, of course.
Thanks for the in-depth explanation!
True.
For a feature-rich software such as Opus, getting help from the responsive developers on the forum is priceless (quite literally too) :smiley:
