The @hideifpath
modifier (specifically the @hideifpath:!/desktop
in my case) doesn't have any effect for the "Three Button" buttons (no matter if the sub-buttons also have this modifier or not). The "Three Button" button is always shown (but for example the @disablenosel
modifier does work).
Not really a bug, just something that has never been supported.
You'd need the modifier on the button itself (not the sub-buttons), but there's no way to add modifiers to that currently.
Yup, that's what I thought, the modifiers (as a separate tab/category) can currently be added only on the WSH script buttons, something similar on the parent that would apply to children would be needed for the Three Buttons and similar.
Sorry to Up an old post but...
Still not possible to hide a Three-button with @hideifpath ?
If not, I would really appreciate if you could move this request up the todo list.
Try
@hideblock
Thanks for this workaround
