More issues
After I started working regularly with version 13, I encountered a few more problems:
  1. Had a crash while copying mp3 files from HD to an external USB device. (V 13.13)
  2. Encountered massive issues with the filter bar. All files disappeared when I entered a single letter, although there were many files that contained this letter in their name. I played around with the options in the filter bar and in the preferences for almost an hour - no change. Now, I wanted officially report the bug, but after restarting my computer and dopus, everything went back to normal and the filter bar is now working as expected. Couldn't reproduce that so far and can't remember I did any specific action before. I was just browsing preferences and file format and did several adjustments. Hopefully it's not some kind of memory corruption, I know these kind of bugs are hard to find. Will let you guys know when it happens again.
  3. I'm having issues with the global filters. In DO12 Desktop.ini was specified in a global filter and it seems the configuration has been imported. But even when I disable all options in the global filter preference page, it's still active? So I currently can't get rid of that. Not an issue, because it's helpful but just want to mention.
  4. Some Labels used for formatting are not working any longer on directories of USB drives f.e.
Sorry for the long mail. Feel free to split it to multiple threads if you prefer. Oh and still appreciate all the tweaks and improvements you guys have added, so don't get me wrong.
Thanks!
It's not possible to split one post into multiple threads, unfortunately.
Please Ask one question per thread
Okay, I might repost in a few weeks, but I'm currently a bit short on time. I would at least take a look to the crash.
Thanks!
We can look at the crash if you submit the crash dumps for analysis, otherwise it's a bit hard to know.
Unfortunately there's no data available...
