Not sure if this is a bug, exactly, but whenever I have two directory panes open in a window (i.e., Dual Vertical, or Explorer with a secondary pane open), regardless of which pane has the focus, using the scroll wheel on my mouse will only scroll the left pane. In other words, I can't use the scroll wheel to scroll the right pane, even when it has the focus.
Can anyone else confirm that this is also the case on their install of DOpus? Using 8.2.2.4 U on my machine.
When I click on the File Display Border (that displays the hotpaths) or the Scroll gadget (the gray rectangle in the scroll bar) that allows me to use the mouse scroll wheel for the desired file display.
The same thing also applies to the Folder Tree, I just click where it says "Folder Tree" and I can scroll it with the mouse wheell too.
When DOpus is active and I move over any lister and use the scrollwheel it just will scroll whether the lister is active or not (dual). This should be the normal behaviour.
What type of mouse are you using, and are you using the latest version of the drivers for it?[/quote]
Hi nudel - I'll have to check (answering this from work). I think you might be right that it has something to do with my mouse / drivers etc, since it appears others don't have this problem.
