I'm on the latest build (13.24.9) and when a file is selected in the lister, and use the scrollwheel somewhere else (higher or lower in the list of files), everything gets selected from the single selected file up to the file underneath my cursor. It only happens when turn the scrollwheel downwards (I mean, towards my hand, not away from it). I'm not sure when it started by I think, since I installed the latest.
Very funny. But no, it doesn't do that in Windows Explorer (I tested that of course) - and it does it with another one of my mouses with scrollwheel. It is definitely in Opus. It could be because of something I do in a script - e.g. in my vertical toolbar with dynamic buttons - possibly some incorrect code which now happens to "throw up" certain unanticipated consequences. PS. I just noticed that when I scroll down above any of my toolbars, it maximizes the Opus listener (and minimizes it again when I scroll down over a toolbar in the maximized window). This is what the lister normally does when I double-click on a toolbar.
Ok it's solved. It was an Auto-Hotkey script which I must have started by accident yesterday. And because status Icons in Windows 10 do not remain in their visible space even if you explicitly demand it, the AHK icon wasn't visible.
Problem solved, and the Opus team is vindicated of all charges (but Windows is not).
