Move As and Copy As in W7 context
Does anyone know how I can add the Move As and Copy As function to the (I assume) Windows context menu that comes up when you right click to select a file? That'd be so handy! TIA
Robin
Settings --> File Types --> All files and folders --> Edit --> Context Menu then add the relevant commands.
Regards, AB
Cheers! Never done anything like before so that was quite exciting. :slight_smile:
GO THE MAROONS
