Move Filter
Goodmorning!
I really like the possibility "Copy Filter" in the dropdownmenu "Copy Files" as is preserves the directory-structure while copying a set of files.
Is it possible to do the same with "Move"? e.g. I like to move files out of the "my documents"-folder which are older than 5 years to a backup-folder while preserving the directory-structure.
Or am I overseeiing something?
Thanks in advance,
Rien/
Oh no! Read the manual before asking!! I allready found it!!! Sorry!!!!
Your one, then two, then three, and finally four exclamation points usage made me smile. Thanks! :slight_smile:
Did you find something in options, or did you make a button?
Thanks.
The same Copy Filter works with both moving and copying.
See Filtered Operations for more.
