Yes. Just add the folder(s) to the TO=
part(s) in your script. No slowdown
If I add TO="' + folder + '/JPEG/\\0"';
Then How define the Other File Types?
files to Pictures/PNG folder and All .psd
file should Move in to Pictures/PSD folder. then how to write that? If you have time then plz show us the way!
my other solution is add the Sub folder name in to the very first variable
var Folders = { "Pictures/JPEG": [ "jpg" ], "Pictures/PNG": [ "png" ], }
and it's work
i think this is the only logical and easiest way.... or is there something better?
You could use the extensions in the TO path, as an alternative.
It's scripting. You can do whatever you want, really. Use whatever works best for how you want it to function.
Please write some example code; make us better understood
