Okay @lxp, just to making sure I'm following you, I already have the "Label" and "Status" columns displaying, correct (in my above screenshot)? And the information for the labels/statuses is still stored in the metadata, it just isn't shown in the metadata panel, but BackupMeta will grab that information which I can then apply to the folders/files from my old machine, correct?
Yes
Okay awesome, that will save me the time of having to redo all of the labels/statuses myself.
So with the re-labeling/re-statusing of the folders/files from the old machine figured out, does anyone know why my custom icons are half displaying? Should that question be moved over to it's own thread?
A new thread would be better, as finding the details in this one is difficult.
Please show the label definition in Preferences, too.
