hello, sorry for another question~
i recently start trying to use NerOpus bar, but whenever i try to get opus to run the button to execute the batch file, instead of running the batch file from the temp dir, it just opens a cmd prompt titled: C:\Windows\SysWOW64\cmd.exe
saying this: C:\Users\me\appdata\local\temp>
so it never runs the batch...
is there anyway to fix this?
sorry about long delay!
i found solution, but i'm not sure of cause...
for some reason, my file association on .bat files where errored.
i used the .reg from this site: dougknox.com/xp/file_assoc.htm to get my .bat association back, and now neropus works!
