Navigating to a Shortcut's Destination
Situation:
I have a shortcut to a file and instead of launching the file, I'd like to immediately jump to that file's location to view other related documents. I'd like to launch a new lister, tab, or navigate to the folder by either pressing a button or an entry in the context menu (preferred).
Is this possible? If so, how?
Thanks.
Try a command like
Go NEWTAB=nofocus,findexisting OPENCONTAINER=target
to open in a new tab (without giving it the focus), or
Go NEW OPENCONTAINER=target
to open in a new window, or just
Go OPENCONTAINER=target
to open in the current lister.
I can't remember if these commands will also work outside of Opus (e.g. in the context menu when you right-click a file on the desktop) but if they don't then you can use this small "OpenContainer" program:
pretentiousname.com/miscsoft/#OpenContainer
Thanks.
I've been able to implement two of these as a new button on my toolbar and modify it to automatically refresh as well.
MUCH Thanks!
Well, it's seems you're all set for handling this ~inside~ Opus...
And if you want to have a right click option for this when actually on the desktop (i.e. not in an Opus lister, since Nucel was right - even using dopusrt, the Go OPENCONTAINER=target command does not work properly from desktop) then you can use Jon's old utility from Nudel's site, paste the following into a blah.REG file, right click on it and select Merge... and that will take care of the desktop.
[code]Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\lnkfile]
[HKEY_CLASSES_ROOT\lnkfile\shell]
[HKEY_CLASSES_ROOT\lnkfile\shell\opencont]
@="Open Container"
[HKEY_CLASSES_ROOT\lnkfile\shell\opencont\command]
@=""C:\Program Files\opencontainer.exe" "%1""
[/code]
Notice that opencontainer.exe is called from C:\Program Files\ - put it somewhere else if you'd like, then modify the path in the .reg file... but when run it won't open in a new tab :frowning:.
