Navigation in Dual Display
Is it possible to set it up so that DOpus when you go into Dual Display mode it has a navigation on each side of the dual display that control each side? This is what mine looks like, but I want buttons on the headers that read off the path location or something similar.
Select Preferences / File Displays / Border / Display as a toolbar instead of Display as a static header.
As an aside is there a way to make it so that the borders close when you exit dual display? It keeps it open when I'm not using dual display.
Not when using the toolbars there. They are designed to contain the path field, which you would normally want to see all the time.
What I mean is can I close it when I go back into single view mode? I already have a toolbar setup to work with single view and would like it to show. Like the two toolbars that are highlighted in red are redundant and I want the green one to close when in single view mode.
You're clearly using the Pro version so I have unlinked your account from the Light licence.
Please link your account to your Pro licence.
