sri
1
I need the code for a toolbar button which when
- left clicked should create shortcut(s) of selected item(s) in the same pane
- middle clicked should create shortcut(s) in a startup folder (C:\Users\username\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup)
- right clicked should create the shortcut(s) in opposite pane
Thanks in advance.
abr
2
You maybe have to adjust your path.
<?xml version="1.0"?>
<button backcol="none" display="label" textcol="none" type="three_button">
<label>Neuer Schalter</label>
<icon1>#newcommand</icon1>
<button backcol="none" display="label" textcol="none">
<label>Shortcut HERE</label>
<function type="normal">
<instruction>COPY Makelink=shortcut HERE</instruction>
</function>
</button>
<label>Copy in destination</label>
<instruction>COPY Makelink</instruction>
</function>
</button>
<label>Shortcut in roaming</label>
<instruction>COPY Makelink TO "C:\Users\username\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup"</instruction>
</function>
</button>
</button>
