i use version 12 and need some help to do the following, i want to:
i have a lister that starts in search pane with preview, as a liste launched with mouse button combination (hence if i choose setting "open last active lister" double clicking desktop the search lister preview opens if i just used that and i dinw want that i want the below behaviour)
when double click desktop opus should open in commander view
for all views i want to expand date full, width of file name app 6 cm, type app 3 cm. And i want to open the last folder that was open before closing opus
To make Opus re-open the last used folder, and remember the last closed lister layout automatically, turn on Preferences / Launching Opus / Default Lister / Update Default Lister automatically when closing a Lister. You may also want to turn on either of both of the two options above it, to avoid having it remember and modify settings you don't want it to.
hello leo
thanks, i did that but the remaining problem is that if i opened a lister in one pane view and closed it, then after closing it and double clicking desktop the standard lister opens but also in one pane view and not 2 pane view. So what i want is to always open in 2 pane view BUT with the foldes i opened last.
You could have an OnOpenLister script which changes things back to how you want them if you'd modified them before closing the last window.
Without using a script, the choice is to automatically remember the previous lister layout and its folders or to remember a fixed lister layout and folders that don't change until you explicitly save over them.
