Nerviges Problem/Bug mit Drag & Drop
Hallo,
Mir ist ein sehr nervender Bug aufgefallen.
Wenn ich mein System neu starte, und die Dopus Fenster geöffnet
werden, also die wo beim System herunterfahren noch offen waren,
funktioniert Drag & Drop in den Fenstern nicht. Ich kann keine Markierten
Dateien/Order ziehen oder sonst was mit Drag & Dop machen.
Passiert wie gesagt nur bei Fenster die beim Systemstart automatisch
geöffnet werden...
EIne Idee bzw. Lösung?!?!
my fault....here is the Text in english:
When Dopus windows are automatically opened by system start, i mean
the not closed windows when system going down, Drag & Drop will
not work. That behaviour is really annoing!!
Any ideas or suggestions??
Drag & drop of what to where? What are you dragging from and to that doesn't work?
Any kind of drag & drop....
for example drag a File to an other folder (copy)
or drag marked files to an other Dopus window for copy....
You can check two options (in the german version):
-> Voreinstellungen -> Lister -> Dateianzeige ->Drag&Drop in Unterordnern zulassen
-> Voreinstellungen -> Lister-Anzeigemodi -> Power-Modus -> Mausschalterverhalten -> for left/right/middle mouse buttons Drag&Drop might be deactivated.
@abr
Can you perhaps offer a better translation here ?
The first sentence is very difficult for me.
I have roughly , "I am fallen from a bug of very much nerve."
The main body is easier, and does seem to correspond to the author's translation.
Correct ???
[quote="Scred"]@abr
Correct ???[/quote]
Oh, sorry. He wrote, he noticed an annoying bug: when restarting the system, he won´t be able drag&dropping between listers, after the last opened session was reloaded. It happens only when he uses the lister, that opens automatically after Opus´ start. He asks for some hint or solution.
My tip was, that he checks
Preferences -> Listers-> File Display -> allow drag&drop in subfolders
-> Preferences -> lister display modes -> power mode -> mouse button behavior -> for left/right/middle mouse buttons Drag&Drop might be deactivated.
for this is most likely not a bug, but an unintended setting.
Thankyou abr.
That makes sense.
Danke
Sorry for the english....
@abr:
I checked the options you mentioned, they are correct. The Problem is
different. This bug/behaviour does not affect all lister. For example,
when i start today, 4 Lister windws are reopened and one Window you
can not do drag & drop (any kind of drag & drop). The other 3 windows
do work correctly!
Somtimes, there are more windows that do not work correct (i mean
drag & drop), sometimes all windows do not. I was not able to see a
pattern, why the windows act like that.
I use Detail-View, by the way in all windows...
Greets
If you leave the windows open, exit Opus via the tray icon, then restart Opus via the start menu, you should get the same windows open again.
Is it the same ones which do an don't allow drag & drop after restarting, or does it change?
Are you using Opus 9.1.3.0 or an earlier version? Recently the way Opus starts after system boot was changed to make it start later, which might help with this sort of problem. (Before, Opus was sometimes being started before things it depended on had become ready. Strange that the OS lets that happen, but it should be better now.)
I use 9.1.3.0
I closed dopus, like you told me. After restarting Dopus, all windows
work fine. Also the window, where drag & drop does not work.
Seems like the problem happens only when booting system. Maybe
Dopus starts to early?!?!?
But i still do not understand, why not all windows have the drag & drop problem...
