Nested Sub-Tabs Not Displaying in Button Script Dialog
The nested sub-tabs in the button script dialog are not rendering properly. Only the parent-level tab is visible, while all child/sub-tabs within the nested structure fail to display.
Requesting a fix to ensure all nested sub-tabs become visible and functional. Thank you!
Script Code
var $ = this, xdlg, xcrt, xmd, xutil;
function OnClick(clickData) {
	$.xutil = DOpus.FSUtil;
	$.xcrt = DOpus.Create;
	$.xcmd = xcrt.Command;
	$.xdlg = DOpus.Dlg;
	$.xdlg.window = DOpus.Listers(0);
	$.xdlg.title = "ZService";
	$.xdlg.template = "P0";
	$.xdlg.detach = true;
	$.xdlg.Show();
	$.loadListView();
	while(true){
		var Msg = $.xdlg.GetMsg();
		if (!Msg.result) breaks;
		var focus = Msg.focus;
		var event = Msg.event;
		var mctrl = Msg.control;
		var value = String(Msg.value);
		var index = String(Msg.index);
		var data = String(Msg.data);
		if(focus){
			$.xlog("The " + mCtrl + " Focus...");
		if(mctrl === "editBtn"){
			$.xedit();
		if(event === "drop"){
			$.xlog("Drop Event...");
function xedit(){
	$.xlog("Editing...");
	var listView = $.xdlg.Control("listview1");
	//var subitems = listView.GetItemAt(1).subitems;
	var subitems = listView.value.subitems;
	var count = subitems.count;
	for(var i = 0; i < count; i++));
		subitems(i).text = "new_" + i;
function loadListView(){
	var dataList = $.getDataList();
	// Batch load data into a list
	// listView.Datas = dataList;
	try{
		for(var i = 0; i < dataList.length; i++));
			var rdata = dataList[i];
			// Populate a list with single-row data
			// listView.AddData(i, rdata);
			var rid = listView.AddItem(rdata[0]);
			var items = listView.GetItemAt(rid);
			var subitems = items.subitems;
			var oee = i % 2 != 0;
			for(var d = 1; d < rdata.length; d++));
				//$.xlog(rdata[d]);
				subitems(d-1) = rdata[d];
				if(oee) subitems(d-1).bg("#303030");
			var cell3 = subitems(2);
			if(String(cell3).search("/08/") > 0)}
				cell3.fg("#3099ff");
				cell3.styles("u", "b");
				//cell3.styles("b", "i", "u");
				//cell3.styles("u");
			var cell5 = subitems(4);
			//$.xlog(cell5);
			if(Number(cell5) > 2000)}
				cell5.fg("#FFFFFF");
				cell5.bg("#F00FFF");
				cell5.styles("b");
		listView.columns.AutoSize();
	}catch(err){
		$.xlog("error message: " + err.message);
function getDataList(){
	var datas = [
		[1001, "PRO-SHA", "UW-F20-10", "2005/07/01", "45.2", "1500", "N", "200", "v1.3.13"],
		[2001, "PRO-SHA", "UW-F20-11", "2006/06/12", "40.23", "2343", "Y", "343", "v2.5.1"],
		[3001, "PRO-SHA", "UW-F20-12", "2006/08/20", "53.39", "1120", "Y", "90", "<a href='dopus.com'>v1.4.22</a>"],
		[4001, "PRO-SHB", "UW-K45-S4", "2007/05/23", "58.9", "300", "N", "10", "v2.8.0"],
		[5001, "PRO-SHB", "UW-<font color='#FF0000'>K09</font>-G5", "2008/03/13", "60.33", "532", "Y", "20", "v4.6.1"],
		[6001, "PRO-SHB", "UW-K21-R3", "2008/09/14", "64.78", "1430", "N", "180", "v1.1.19"],
		[7001, "PRO-SHC", "UW-J33-56", "2010/04/28", "67.45", "2800", "Y", "520", "v7.12.04"],
		[8001, "PRO-SHC", "UW-J52-24", "2011/08/19", "70.49", "3740", "Y", "940", "v9.15.08"],
		[9001, "PRO-SHC", "UW-J63-39", "2013/01/04", "70.14", "5999", "Y", "1260", "v11.9.03"],
		[10001, "PRO-SHC", "UW-J89-75", "2013/11/16", "67.78", "7810", "Y", "2790", "v11.12.03"]
	return data;
// print log
function xlog(str)}
	DOpus.Output(String(str));
Resources Code
<resources>
	<resource name="P0" type="dialog">
		<dialog height="183" lang="chs" maximize="yes" minimize="yes" opacity="230" resize="yes" title="DService" width="374">
			<control height="175" name="tab1" type="tab" width="366" x="5" y="4">
				<tabs>
					<tab dialog="P1" />
					<tab dialog="P2" />
					<tab dialog="P3" />
				</tabs>
			</control>
		</dialog>
	</resource>
	<resource name="P1" type="dialog">
		<dialog height="158" lang="chs" title="DataList" width="360">
			<control halign="left" height="12" name="xid" tip=" " type="edit" width="64" x="34" y="7" />
			<control halign="left" height="8" name="static1" title="Id:" type="static" valign="top" width="12" x="18" y="10" />
			<control fullrow="yes" height="132" name="listview1" type="listview" viewmode="details" width="360" x="0" y="26">
				<columns>
					<item text="Id" />
					<item text="Project" />
					<item text="Name" />
					<item text="Date" />
					<item text="Price" />
					<item text="Sales" />
					<item text="Status" />
					<item text="Likes" />
					<item text="Version" />
					<item text="Download" />
					<item text="Remark" />
				</columns>
			</control>
			<control halign="left" height="8" name="static2" title="Name:" type="static" valign="top" width="27" x="120" y="9" />
			<control halign="left" height="12" name="xname" tip=" " type="edit" width="73" x="148" y="7" />
			<control height="14" name="editBtn" title="Edit" type="button" width="37" x="247" y="6" />
		</dialog>
	</resource>
	<resource name="P2" type="dialog">
		<dialog height="159" lang="chs" title="BaseList" width="360">
			<control halign="left" height="12" name="pname" tip=" " type="edit" width="64" x="47" y="6" />
			<control height="134" name="listview2" type="listview" viewmode="details" width="360" x="0" y="25">
				<columns>
					<item text="Id" />
				</columns>
			</control>
			<control halign="left" height="8" name="sname" title="Name" type="static" valign="top" width="20" x="14" y="8" />
		</dialog>
	</resource>
	<resource name="P3" type="dialog">
		<dialog height="158" lang="chs" title="AddInfo" width="360">
			<control height="102" name="tab2" type="tab" width="360" x="0" y="56">
				<tabs>
					<tab dialog="P4" />
					<tab dialog="P5" />
					<tab dialog="P6" />
				</tabs>
			</control>
			<control halign="left" height="8" name="sid" title="Id:" type="static" valign="top" width="12" x="18" y="10" />
			<control halign="left" height="12" name="fid" tip=" " type="edit" width="64" x="35" y="7" />
			<control halign="left" height="8" name="sname" title="Name:" type="static" valign="top" width="29" x="119" y="10" />
			<control halign="left" height="12" name="fname" tip=" " type="edit" width="64" x="151" y="8" />
			<control halign="left" height="8" name="sversion" title="Version:" type="static" valign="top" width="29" x="10" y="34" />
			<control halign="left" height="12" name="fversion" tip=" " type="edit" width="64" x="44" y="32" />
			<control halign="left" height="8" name="sstatus" title="Status:" type="static" valign="top" width="26" x="129" y="34" />
			<control height="40" name="fstatus" type="combo" width="64" x="158" y="32">
				<contents>
					<item text="Yes" />
					<item text="No" />
				</contents>
			</control>
			<control height="14" name="addbtn" title="Add" type="button" width="50" x="259" y="31" />
			<control halign="left" height="8" name="sprice" title="Price:" type="static" valign="top" width="21" x="234" y="10" />
			<control halign="left" height="12" name="fprice" tip=" " type="edit" width="64" x="260" y="8" />
		</dialog>
	</resource>
	<resource name="P4" type="dialog">
		<dialog height="87" lang="chs" width="356">
			<control height="87" name="group4" title="Group4" type="group" width="356" x="0" y="0" />
			<control height="78" name="listview4" type="listview" viewmode="details" width="356" x="0" y="9">
				<columns>
					<item text="Id" />
				</columns>
			</control>
		</dialog>
	</resource>
	<resource name="P5" type="dialog">
			<control height="87" name="group5" title="Group5" type="group" width="356" x="0" y="0" />
			<control height="15" name="datetime1" title="ζ—₯期/既间选取器" type="datetime" width="67" x="156" y="36" />
			<control halign="left" height="8" name="date5" title="Date:" type="static" valign="top" width="20" x="132" y="40" />
		</dialog>
	</resource>
	<resource name="P6" type="dialog">
			<control height="87" name="group6" title="Group6" type="group" width="356" x="0" y="0" />
			<control height="14" name="palette1" title="调色板" type="palette" width="50" x="172" y="35" />
			<control halign="left" height="8" name="color6" title="Color:" type="static" valign="top" width="26" x="146" y="39" />
		</dialog>
	</resource>
</resources>
Isn't this the same issue (The problem that the script tab group interface cannot correctly save nested tab groups still exists) you keep creating new posts about?
I think you've been heard, but this seems not to be on the priority list for the moment. Even if I also encountered this issue and would like it solved, it's probably not that easy.
Anyway, I don't think keeping doing new posts will speed up resolution but it will make it harder to track for everyone.
Thank you for your reminder, and I sincerely apologize if my repeated posts caused any inconvenience.
I reposted due to eagerness to resolve the nested tab group saving issue, not intending to complicate tracking.
I fully understand the team's current priorities and recognize the complexity of this problem requires time.
Please let me know if there's a more effective way to provide information or assist with testing.
Thank you again for your patience and understanding. I'll stay tuned for updates.
We're probably not going to support nested tabs any time soon. You may want to think about redesigning your UI.
