No response when right click folder name in location bar
It's a issue since DO 10.0.0.3, when I right click a folder name in location bar, there should be a context menu for it. It's okay in DO 10.0.0.2, but I found some times it's no response - no context menu when I right click folder name in location bar since DO 10.0.0.3 to 10.0.0.6.
When this issue happens, the issue remains although I open new lister, but if I quit DO completely (include icon in taskbar) and re-open DO again, the issue will be resolved.
Chances are it's a shell extension going wrong with Opus, though I'm not sure what changed in 10.0.0.3 that might cause that.
Try the suggestions in this FAQ: Crash, exit or high CPU when right-clicking certain files.
I try all DO 10 beta release from 10.0.0.1 to 10.0.0.6 on my same PC, it's okay in 10.0.0.1 and 10.0.0.2.
This issue is same in DO 10.0.1.0.
Did you try the suggestions in the FAQ I linked?
