[quote="leo"]Does anything happen when you double-click them?
What are you filetype double-click settings set to after you were messing with them the other day?[/quote]
Now Leo, be nice...
The Left-double-click is still where I set it
"C:\WinMgmnt\Files\Managers\Directory Opus\dopusrt.exe" /CMD Copy FILE {filepath$} MAKELINK=shortcut TO Recent
(remember, you told me the "Go" had to "go"
-- OK, since you asked, I thought to myself "Self, you probably screwed this up", so I took that command line out, and now the WAV file association works again.
So (even though the command-line above isn't doing exactly what I want), I can't have both the association AND the command-line?
So if you have left double-click set to do nothing else but make a shortcut to the file you've double-clicked on, why do you think double-clicking a sound file would play it?
[quote="jon"]If you want the double-click action to go on and open the file as well, you need to tell it to do that. E.g.
{filepath$}[/quote]
OK Jon, now I'm totally confused.
I had put in the command-line above before, in trying to work out the RecentX issues. Then I realized that double-clicking WAV files wasn't making any sound. Then I took the command back out, and the WAV file sound was back.
Then (just now) I pout that line of code back in, and the sound (WAV) still work.
It was bad enough when I neither understood nor was able to get RecentX and DOpus to play friendly; now I don't have a clue what is working or not or why.
I thought I was sort of OK with making this work, but now....
