I have a problem in Adobe Photoshop which I suspect comes from Directory Opus. Having opened a file in Photoshop and treated it, I used to "save as" a jpeg in the same folder. Now when I try to do this, I receive the following message:
I am the administrator! How do I contact myself and what do I do? Would very much appreciate help with this
Adobe Photoshop has nothing to do with Directory Opus.
Can you create for example a new text/image file in that folder or copy some file to it?
Use Explorer to rule out Directory Opus.
