Not highlighting search phase
After upgrading to DO 12 i noticed that when I do a search the previous entered words are not highlighted when I click on them. I can't be sure now but I think they were highlighted in DO 11. Is there a way to highlight the words when they are clicked on?
Check that Preferences / File Displays / FAYT and Filter Bar Options / Highlight matches is enabled.
Assuming we are talking about this:
That option is set but I don't think it has to do with what I'm talking about. Try this:
  • Press ctrl-f
  • Type in something to search for and search
  • Close the search window.
  • Press ctrl-f.
  • Click on the word you just typed in. It should be highlighted but isn't.
I take it there's no way around this. But in case it is seen by Jon, something I just noticed for this is that the problem I mentioned is only when the Advanced tab is selected. The Simple tab highlights the previous text correctly.
