I have 3 monitors on my XP system.
Is there any way I can force Opus to open a lister window on the monitor on which I double click.
At the moment a lister opens on the monitor on which I closed the last one I opened.
Regards Alan F.
Regards Alan F.
Opus Preferences :: Layout :: Default Setting (Tab) :: Position under mouse cursor (Checkbox).
That should work for you.
You can do it but exactly how you do it depends how you're opening the lister.
What do you do to open the lister (double-click desktop? tray icon? quick-launch icon?) and what is that configured to do (open the default lister? open a layout?)?
Thanks folks
That's cracked it. Plus unticking the "Opening Listers" "position" box.
Now works a treat - no more swivelling neck to find the windows!
Configurability - a double edged sword .
Alan F.
